up grade motor
Must be the flavor of the week wantin' to put cams in.
https://www.f150online.com/forums/pr...150-5-0-a.html
Couldn't tell ya on the headers. Stock manifolds work for me.
Adrianspeeder
Adrianspeeder
Long tube headers are better for the most part, lots of info on this out there. You truck has a roller 302 so cam swap is pretty straight forward, if you do the math and don't get something with too much lift for your stock rollers etc. If you don't want to get into the heads or get new heads, find a stock HO cam and run that. Speed density will keep up for the most part, WOT may give you a slight lean condition, but nothing detrimental
