Ignition problem?
Old Sep 28, 2011 | 10:34 AM
Garbar's Avatar
Ignition problem?
Wondering if you guys can point me where to start looking. Problem is when the truck has been sitting for a day it will not turn over the first try, so i turn the key for another try and it will start.
Would this be the starter solenoid? How can i check it or should i be looking some where else such as the starter maybe?
Old Sep 28, 2011 | 12:29 PM
Steve83's Avatar
The solenoid is on the starter, so if you're looking at it, you're looking at the starter. What happens when it doesn't crank? Do the radio & dash lights stay on? If so, it's either a bad actuator in the column or the ig.sw. Do you hear a click under the hood when the key moves to START? If so, it's probably a bad starter relay or the solenoid on the starter. Read these captions:
Old Sep 28, 2011 | 08:03 PM
losthillbilly73's Avatar
also check ur battery terminals. ive had terminals that would let everything come on but not have enough of a conection to start the truck so make sure they are good n tight and clean
