Hood light inop
Old Mar 19, 2011 | 08:09 PM
devildog1024's Avatar
Hood light inop
Just bought a 93 F150 (my second one ) and there's some little issues that I'm cleaning up. The simplest is the hood light. It doesn't work and I can't find a switch to check. Where is the switch located? Thanks in advance.
Skip
Old Mar 19, 2011 | 10:43 PM
MI02SVT's Avatar
did you check the bulb first or see if you have power at the bulb
Old Mar 20, 2011 | 09:52 AM
Sure did. New bulb and no power. All fuses are good.
Old Mar 23, 2011 | 12:25 PM
DragonBlod's Avatar
Trace your wire? these get cracked and grounded out a lot.
Old Mar 26, 2011 | 12:29 AM
Steve83's Avatar
The switch is inside the light fixture.
But if the LG/Y wire isn't hot at all times, there's a circuit fault. Do all the OTHER courtesy lights work? How about the radio memory?
Old Mar 26, 2011 | 10:38 AM
OK, finally found my meter and after some "duh" moments, figured out there's a mercury switch in the lamp socket. No trons to the light assy. All other lights are working though. Checked every fuse in both panels and all are good. Time to start working back to find the fault.
Old Mar 26, 2011 | 11:06 AM
Steve83's Avatar
...or just overlay a new wire from any LG/Y that's hot to the light fixture.
Old Mar 26, 2011 | 12:47 PM
Success! Took apart the harness and switch assy, cleaned everything up, rigged the corroded positive terminal on the harness and I now have a working hood light. Thanks to all for your input.
