lifting an 80-96 alignment???
Old Apr 26, 2012 | 10:31 AM
  #61
Beastly_95's Avatar
but once you go bigger then a 6" system then put 2" coil spacers in be prepared for bigger axle drop brackets on a TTB i have that problem and i wore one tire out crazy fast .....
Old Apr 26, 2012 | 09:32 PM
  #62
russo2's Avatar
So are you saying a 5.5" superflex spring on a 4" long arm drop kit is no good?
Old Apr 29, 2012 | 11:30 AM
  #63
terrapinflyer's Avatar
Hello, what's TTB /TIB? Thanks, Peace, Dave.
Old Apr 29, 2012 | 04:45 PM
  #64
russo2's Avatar
TTB, twin traction beam TIB, twin I beam.
The style of front suspension on the old body style f150/250
Old May 5, 2012 | 10:34 PM
  #65
Thanks Russo. Peace, Dave.
Old Sep 12, 2012 | 12:02 PM
  #66
Swat13's Avatar
I have personally lifted an 84 Bronc and now my 93 F150 Flare Side 2"s. The Bronc with springs and now the truck with Daystar spacers. I believe anything 2" and under can be aligned correctly with Adjustable Caster/Camber bushings. The alignment bushings I bought allowed for up too 4 degrees of caster change and I found them at NAPA. I didn't use all of that 4 degrees so could probably go a bit higher. I did add a bit of caster back with them as well. The truck, as did the bronc, tracks strait, the steering wheel returns to center well, and I have no adverse tire wear as it is aligned correctly. I aligned it in my garage with tape measure and angle finder. I had my buddy at Firestone check it and confirm that it was in spec.
I chose the spacers over a new coil as I wanted to maintain the softer stock spring rate. All of the coils I looked at have a much higher spring rate except the Deaver Superflex coils which are made for a solid axle. They can be used but you have to switch to that style lower bucket and cut them down for the ride height you want. I may use them to add a couple inches of lift inthe future. Then I know I will also add TTB drop brackets because the caster will be out so far the adjustable caster cambers brackets won't work by themselves. I may or may not go with an extended radius arm.
I adjusted the rear springs by taking out the thick overload leaf and replaced it with leaf I shortened from another F150. It rides nicely.
Old Sep 12, 2012 | 08:26 PM
  #67
russo2's Avatar
Good to hear someone with success.
If you wanna buy some extended radius arms, I have a set for sale.
Old Sep 13, 2012 | 01:29 PM
  #68
Swat13's Avatar
I PM'ed you, what you got?
Old Sep 13, 2012 | 06:12 PM
  #69
russo2's Avatar
Message sent
