5.8L Exhaust Manifold
Old Jul 14, 2010 | 10:26 AM
stumper's Avatar
I've grown tired of battling exhaust leaks with my shorty headers and have decided to put the original manifolds back on my 1994 F-150 with the 5.8L.
My question - do these factory manifolds require a gasket?? It was a number of years back that I put the headers on but I seem to recall there was no gasket when I took the manifolds off (they were the original set up).
Old Jul 14, 2010 | 10:40 AM
StrangeRanger's Avatar
Fel-Pro #1415
Old Jul 14, 2010 | 10:45 AM
stumper's Avatar
You're saying they did come with gaskets?
Old Jul 14, 2010 | 12:21 PM
I'm saying that is the gasket part number. Ford put them together at the factory without gaskets. Trying to do so with a manifold that has been heat cycled is a really bad idea. It will never seal up properly. Spend a couple of $$ and buy the gaskets.
Old Jul 14, 2010 | 12:33 PM
stumper's Avatar
Got it and I'll do that. Thanks.
Old Jul 14, 2010 | 11:32 PM
GTRider245's Avatar
And then put them on the headers before you buy manifolds. Unless you bought crappy headers, they should be fine.
Old Jul 19, 2010 | 12:20 PM
aswaff400's Avatar
take your headers off, hold a straight edge to the flange, see if theres any high or low spots, if there are any run the entire flange on a belt sander flat and even. i had LT headers on my truck for 10k miles and didnt have one leak
Old Jul 24, 2010 | 06:45 PM
stumper's Avatar
I didn't have to change to the manifolds - turned out that my exhaust leak was from the EGR tube and it was hiding under the cloth sleeve!! I'm really glad because it is virtually impossible to get at the very rear bolt on the passenger side of these headers (cheap *** Summiit shorties that I would never buy again). After some doing to get the old rusted EGR tube off and $75 for a new one from Ford .... we are back to normal.
Old Aug 7, 2010 | 03:02 PM
Steve83's Avatar
Gaskets suck. I just removed them from a reman engine with only a few Kmi on them. They had already rusted out. I put the used manifolds back on without gaskets, and they're totally sealed now. No machining. Read these captions:
Old Aug 7, 2010 | 05:22 PM
GTRider245's Avatar
Crappy gaskets suck. Good ones do the job just fine.
Old Aug 8, 2010 | 01:26 AM
Steve83's Avatar
Then I've never seen a good one, and NO gasket does the job for less $$ & effort. I don't have them on my exhaust, I removed them from that truck, I didn't put any on Frank's '75 Bronco, and I've never put them on any Ford engine I've installed, including my CV.
