Cutting out!
Old Oct 26, 2009 | 08:58 AM
hornet41's Avatar
Cutting out!
'93 F150 5L 4x4 w/AOD has developed a very annoying problem. The engine will cut out at random times. It's like you turned the key off and back on!! It's NOT a miss!! It just instantly quits, then comes back on!! It's quick, less than 1/2 second each time it does it. Never does it at idle but will do it under load or steady state running. It's intermittent. Sometimes it will be a day or two between episodes, then it may be every time I drive it!! No computer codes!!!!!!! Plug wires (properly routed),new dissy cap and rotor and plugs(autolite) changed about 2k ago.
This is driving me crazy. I've checked harnesses for bare/worn spots, checked connectors, wiggled this and that in hopes of finding something unusual. No joy!!! I'm open to any suggestions as I'm completely stumped!!!
Thanks 'Mo
Old Oct 26, 2009 | 04:51 PM
When was the last time you changed the fuel filter?
Old Oct 27, 2009 | 08:01 AM
hornet41's Avatar
Filter was changed 2k miles ago.
