Truck wont start....
Old Jun 30, 2009 | 04:27 PM
BIG.D's Avatar
We used the distributor out of my original motor because the plug in is different on the one that came on the motor I got. Using the trucks original ignition module and yeah i routed the spark plug wires the way they were in the diagram. I'm using the coil that was on the truck but I tried using the coil off the new motor but it didnt change anything. I dont have a fuel pressure gauge so I cant check the pressure.
Old Jun 30, 2009 | 04:43 PM
Matts ford's Avatar
did that motor even come out of a truck? you said it was rebuilt- maybe they changed the cam. i really would try the other firing order just in case.
Old Jul 1, 2009 | 12:12 AM
BIG.D's Avatar
Yeah it was in a 86 F150, the guy rebuilt it and used it for a little bit then he took the motor out and scraped the truck because it was a rust bucket. He said when it was rebuilt they replaced the cam but it was just a stock replacement.
Old Jul 1, 2009 | 01:03 PM
Steve83's Avatar
Get a fuel pressure gauge.
Originally Posted by BIG.D
Yeah it was in a 86 F150, ... they replaced the cam but it was just a stock replacement.
The cam for a carb engine isn't the same as for an EFI (in several ways) and neither are the timing cover, water pump, block, intake/exhaust manifolds... I hope you stripped it to a short block & then transferred EVERYTHING. It might eventually run, but it'll never be right until you get the right cam in it.
Old Jul 1, 2009 | 09:33 PM
BIG.D's Avatar
Actually it had EFI on it also. But we got the motor running fine finally and then figured out the problem is the tranny. Its all messed up
