Remove Transfer Case
Old Apr 11, 2009 | 11:23 AM
tomcat6's Avatar
How do you remove the connector rod that goes between the shift lever and the selector lever on the transfer case? The service manual says carefully pry it off, but I'm not familiar with this kind of fastener. I tried for about 30 minutes and made no headway, so I thought I'd ask before I destroyed something. I have a 1995 manual shift transfer case, M5OD transmision, and trying to change the clutch.
Old Apr 13, 2009 | 08:09 AM
GTRider245's Avatar
I am having trouble picturing exactly what you are talking about. Can you get a picture?
Old Apr 15, 2009 | 01:29 PM
tomcat6's Avatar
I'll try - thanks
Old Apr 15, 2009 | 04:45 PM
StrangeRanger's Avatar
He's talking about the Control Rod (7A315) which connects ths shift lever to the Lever, Shaft and Pin Assembly (7B106) which operates the shift mechanism inside the transfer case. If you have access to a Service Manual look at section 07-07B
Unfortunately, the Manual gives no information on how to remove it but does warn to be very gentle in doing it so as not to damage the shift control selector lever.
Thank you Ford for this extreme bit of clarity.
Old Apr 25, 2009 | 09:21 AM
tomcat6's Avatar
Thanks - It DID take gentle prying, with an 18" pry bar and a hose down of penetrating oil. It will work right off with some patience. Now if I can just figure out how to get the hydraulic line off the transmission slave cylinder without the "special tool" that no one has.
Old Apr 25, 2009 | 12:00 PM
masseyman's Avatar
The Haynes repair manual I have shows a method of using one screwdriver and pushing on the release sleeve while gently pulling on the line. It says sometimes this works. It worked for me on my '88 F-150.
Old Apr 26, 2009 | 08:32 AM
tomcat6's Avatar
Thanks - I'm trying that, no luck yet. I think I'm a victim of prior repair by others. I pushed the sleeve back, tugged, pushed, pulled, yanked, whatever. Nothing is coming out without a fight. Probably because I'm just a professional klutz.
Old Apr 26, 2009 | 02:03 PM
Steve83's Avatar
It's easier to just remove the nut from the t-case shift lever & leave the rod attached to those plastic bushings. But you got it...
For the clutch slave line, push it INWARD first, then press & hold that tiny colored ring, and pull the line out. The special tool is nothing but a little fork that fits around the line & sits on the ring. You can make one yourself if you can bend & cut a thin piece of steel, but the pocket screwdriver works fine. If the ring seems not to move, it might have dirt inside - rinse it thoroughly with brake parts cleaner or penetrating oil to get the mud out.
Take a few minutes to look thru the Hydraulic Clutch album linked to my black Bronco in my signature, and this TSB:
Old May 7, 2009 | 08:47 PM
tomcat6's Avatar
Thanks for the advice. I finally got it. Easy once you get the hang of it. If I ever do this again I'm going to just remove the shift levers, drive shafts, x member and drop the whole unit as one piece.
