what axle?
Old Jan 30, 2009 | 10:53 PM
stealthsniper96's Avatar
what axle?
What axles were used on a 93 f150? And how much would a decent set of manual locking hubs be?
Old Jan 31, 2009 | 06:13 AM
Colorado Osprey's Avatar
The axle itself are, I believe Dana/Spicer.
A set of standard WARN replacement hubs should sell for $90-125, premium WARN's for about $30 more. If you are replacing auto hubs you will need a hub nut kit as well $60-80
Old Jan 31, 2009 | 10:31 AM
bigbronc's Avatar
Rear axle is an 8.8 and the front is a Dana 44. Advance has Warn hubs right on the shelf for around $70.
Old Jan 31, 2009 | 11:48 AM
Matts ford's Avatar
a few of these trucks had the dana 28 in the front too. but most had the dana 44
Old Jan 31, 2009 | 07:24 PM
bigbronc's Avatar
I've never seen a fullsize with a Dana 28. Mostly those were for the Rangers, Bronco II, and Explorers. Every fullsize half ton truck I have ever seen since the 70s has a Dana 44 front axle, whether it is independent, or solid axle. I may be wrong, it's happened before, but I would have to see that one.
Old Jan 31, 2009 | 07:29 PM
Matts ford's Avatar
neither have i. but when i was looking up specs for my front ring and pinion on all-data it would only show stuff for a dana 28. then my dad went through a different section and he found the info we were looking for on my dana 44 but it still showed stuff for the 28. i would have to see one in person too.
Old Jan 31, 2009 | 07:49 PM
bigbronc's Avatar
You can't count on Alldata. At best is is Somedata. We use it at work. It is a joke.
