Vibration in Steering Wheel on braking
Old Apr 26, 2001 | 10:40 PM
PumperMike's Avatar
Question Vibration in Steering Wheel on braking
I have an interesting and so far difficult to solve problem. I just purchased a 1995 F-150 two wheel drive, long-bed with the 300 inline six and the 5 speed manual transmission with 93,000 miles on the truck. When I applied moderate to heavy braking the steering wheel moved up and down, not side to side, violently. I had a 1984 F-150 two wheel drive, long-bed with the 300 inline six and the 4 speed transmission with 138,000 miles on the truck and it did the same thing. ( Never tried to fix the problem with the 1984 )
So far I replaced the front rotors, brake pads, front wheel bearings and shocks all around. The problem is a lot less severe, but it is still there. It is worse with the clutch pushed in, it is hardly noticeable with the clutch out and in gear. The tires are in balance with no vibration or shimmy in the steering wheel up to 70+ mph.
Scratching my head on this one.
Anybody have any ideas?
Michael
2000 Expedition XLT, 4X4, 4.6, 3.55
C & C Group
K&N air filter
WeatherTech Vent Shades
Hellwig Sport Tech Anti-Sway Bar
Ford Dual Media AM/FM/Cassette/CD
1995 F150 XL, long bed, 4.9, 5 speed O/D, 4X2
Pioneer DEH-P4100 Head Unit
Old Apr 27, 2001 | 10:01 AM
93F-150's Avatar
Post
PumperMike, I had a similar problem with my ranger. I was told that it was the brake rotors and that it would be fine after having them turned. After having them turned I still had the shakes. I had a u-joint go bad, very bad, truck shook so bad I had to do 30 to get home. After changing the joints I noticed a funny thing, the first time I out on the brakes the shakes were gone! I had these shakes for 60k miles. Just a thought.
93 F-150
CGS Motorsports SI/DO
92 Ranger
254,000 mile daily driver
Old Jul 14, 2002 | 11:25 AM
PumperMike's Avatar
Smile
Replaced U-Joints: Problem still there. U-joints were shot anyway.
Replaced brake drums and brake lining. Fixed problem almost.
Little bit of pulsation in brake pedal sometimes.
Best Regards
Michael
Old Jul 14, 2002 | 11:28 AM
Ford4ever's Avatar
Have you checked the radius arm bushings??
-Jon
Old Aug 2, 2002 | 02:22 PM
spaceman12321's Avatar
Is there movement up and down or shaking up and down? I have a 5spd and the whole column would move because the brakcket broke under the dash that holds it up. It was caused from the pressure applied to the brake, and mainly the clutch. Both pedals are attatched under the dash along with the steering column. Pushing in both would increase the force on it, lowering the column. Not fixing the support bracket will cause you a lot of problems, including dash movement and noise. Mine caused my clutch mastercylinder to go bad because it bent the push rod in the firewall. If it is not that, remove the radiator cap and drive a new truck under it.
Old Aug 2, 2002 | 07:45 PM
PKRWUD's Avatar
LOL!!! Love that last line!!! (my favorite to tell customers: It's like this ma'am, your battery needs a new car.)
Actually, I never would have thought of that as a source of the problem, but it makes perfect sense. Now I'm curious!
Take care,
~Chris
Old Aug 2, 2002 | 10:23 PM
Thats a good one too! Just thought I would add, my column sagged and would bounce slightly over bumps. It really made my change rattle in the ash tray. I might think the support could be broken in many peoples trucks. I could tell something was because the hole column would move up if you picked up on it, and the dash would fall when I applied the clutch.
Old Aug 26, 2002 | 11:02 PM
PumperMike's Avatar
Talking
Hi all,
Solved the problem. Got a new Truck. See signature below.
Best Regards
Michael
Old Aug 27, 2002 | 12:32 AM
PKRWUD's Avatar
Congrats!
Take care,
~Chris
Old Aug 27, 2002 | 10:16 AM
SPROCKET_X's Avatar
wow good excuse to get a new truck...good luck!
