Removing front fuel tank. How to cap lines?
Old Nov 20, 2000 | 10:02 PM
Jason Zaluski's Avatar
Post Removing front fuel tank. How to cap lines?
Hey guys. Taking my front tank out. What's the best way to cap the vent, return, and supply lines from that tank?
1995 F-150 Regular Cab Flareside w/ 302 V8... Mods: DJM Suspension 3/5 Drop Kit, Mass Air, K&N FIPK, Dual Exhaust (no mufflers), Lund Premier Tonneau Cover, Motorsports 9mm Plug Wires, BellTech Nitro Drop Shocks, Trenz Pollished Billet Antenna, A/C Controls and, Door Panels, Superchip, Autometer 5" Tach, Precision Gears 3.73s, TD Chrome diff cover, Trenz Billet Grill, Distinctive Truck Accessories Bumper w/ billet insert and light pockets, Summit Battery Relocation Kit, Cervini's Chin Spoiler, EAI Front Bag Mounts, Firestone 26c Airbags, MAC valves, EAI 5 gallon tank, Thomas compressor, Autometer Pro-Comp A/F gauge, Autometer Pro-Comp Boost Gauge, Autometer triple gauge pillar, II Xtreme Levels C-Notch (through the bed) and bag mounts, BellTech 1" Lowering Blocks, BellTech Tailgate Handle Relocation Kit, 20" KMC Clockers on BF Goodrich 245/40/20s.
Twin Garret T3 Turbos
Old Nov 20, 2000 | 11:16 PM
jamden1's Avatar
Wink
Hey Jason. Don't use a torch! :-)
1992 F150 Supercab SB 4x4 Manual Hubs 302 AOD Ford 8.8 Dana 44 3.55 31x10.5 Ford 15x8 Steel 8 Slot Ralleys Custom Box Liner
Old Nov 21, 2000 | 04:09 AM
signmaster's Avatar
Question
Do you know which type of selector setup you have? My '95 has the in tank Fuel Delivery Module, which would probably be the easiest to deal with. From what I've heard all 4x4s had it in '95 but some 2 wheel drives had one of the other setups. I think my Haynes manual shows them all. I'll try to check it out for you as soon as I have some time.
Old Nov 21, 2000 | 06:27 AM
Post
All I know is my truck has a 2 position switch on the dash. Each tank has it's own pumps, and supply, vent, and return lines. There are a setup of silver boxes that both tanks run through and then up to the engine.
Old Nov 22, 2000 | 11:05 AM
tmcalavy's Avatar
Post
Jason,
If you're replacing the tank, depressurize the fuel system by pushing the fuel inertia button and cranking the engine for minute or two. Then clamp off the hoses going to your tank aways back from the tank. If you're changing the fuel pump in that front tank, consider pulling the bed off/back instead. Much easier to do. Pull the six bed bolts/nuts, unhook your back lights, take the tailgate off, loosen the fuel filler hose clamp(s) and get a buddy to help you lift/slide the bed straight back until you can access the font fuel tank/pump. This will save you ALOT of time, frustration and cussing. You'll only have to move the bed back about 1.5 to 2 feet to get access to the tank/pump. Good luck
Old Nov 22, 2000 | 11:14 AM
Post
I'm trying to fully remove the tank.. and want to know how to cap the lines so fuel permanently.
Old Nov 25, 2000 | 08:06 PM
signmaster's Avatar
Exclamation
Jason,
I checked out my book and there are several options.
1. Does your truck have an external fuel pump?
2. How many "silver boxes"? Only count the ones that look like valves or regulators.
Try to narrow it down. Shouldn't be too hard either way, I just don't want to type all the info for all the possible combos.
Old Nov 26, 2000 | 04:38 PM
Post
1) 2 intank pumps.... no inline pumps
2) 2 silver boxes. One on the return, and one on the supply
Old Nov 27, 2000 | 08:04 PM
Don C's Avatar
Post
why not look to see if you can find a good used fuel tank. then you won't have to worry about capping the fuel lines.
Don C's Avatar
Post
Old Nov 28, 2000 | 01:30 AM
ktodd's Avatar
Arrow
Jason:
Where can we see pictures of your truck? I emailed you awhile ago, did you ever get some pictures? Let us know- it sounds like a cool truck.
-Kevin
Old Nov 28, 2000 | 06:19 AM
Post
Hey Kevin, I'll have you some pictures after this weekend. It's in my garage right now, I'm redoing the front suspension.
