Is my mechanic ripping me off?
Old Nov 7, 2000 | 03:30 PM
donhill's Avatar
Question Is my mechanic ripping me off?
I have an '88 F-150 and the clutch has gone out on me. The mechanic said it will be about 920$ to get it fixed!!
260$ - clutch kit (pressure plate, new bearings, resurfice fly wheel)
170$ - slave cylinder
102$ - master cylinder
40$ - bleeding and hosing
300$ for labor
260$ for the clutch sounds high. One of my friends said he can get me a new one for 90$, which sounds too low.
The truck is undrivable and currently it will cost more to fix it than its worth.
Any input?
Thanks to all that reply!!
-Don Hill
Old Nov 10, 2000 | 12:31 AM
Former Sponsor
Post
Hi Don,
Those numbers aren't too far out of line, remember that in that $260 price is the resurfacing of the flywheel, etc., whereas the price you got of $90 was I'm sure just for the clutch lining.
You may or may not need all new master cylinder & slave cylinder, and those parts add a good bit to the cost. I can't tell you if yours are OK to still use or not, but they may not need replacing, and this mechanic is just replacing *everything*. Then again, it may need it, there's no way for us to know from here, and your mechanic may in fact be doing a very good job. Ask your mechanic about this, if those master & slave cylinders are actually leaking, etc.
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
