post for jimbello
Old Oct 2, 2000 | 08:55 PM
Jetter's Avatar
Post post for jimbello
I read in a recent post that you had a problem with you r temp. gauge and I was wondering what the fix was. Right now the one in my 95 is inop. When I tested it, it shows open (drives the needle full cold.) Thanks for any help you can provide.
Old Oct 2, 2000 | 09:12 PM
Jetter's Avatar
Post
jimbello I saw your first post in a response to cowlady. Then I found your response to machboss. I guess I'm ordering a new gauge too.
Old Oct 4, 2000 | 08:57 PM
Jetter's Avatar
Post
new signature
1995 F-150 XLT SC 4X4 shortbed blue & white 351 5.8 auto.
3.55 limited slip front AND back
JBA stainless steel silver ceramic coated headers
Bassani stainless steel performance Y-pipe & high flow cat
Gibson stainless steel swept-side exhaust (for towing torque)
K&N FIPK
Superchip
Edelbrock IAS shocks
31 x 10.5 BFG A/T K/O
Old Oct 4, 2000 | 09:35 PM
jimbello's Avatar
Post
In my case yes the guage.
I spnt (NO LIE) 3 weeks after work every night under that hood tracing wires checking grounds, I even took the dash apart and I got the voltage readings I was supposed to have.
I did that grounding out the sending unit too.
If you take the wire off the sending unit and touch it to the frame the guage should slam hard HOT. Mine wouldn't even do that.
I finally bit the bullet and bought the assembly and it's been fine ever since.
AND, just to be sure, I put the old guage back in to see if it was just a bad connection. Old guage still slammed below cold....new guage back in and normal so it has to be the guage. Only problem is the cost. for me $100 bucks now I've heard that assembly is going for around $130.......
It is an easy fix though only took me about an hour and a half and that was with doing some cleaning while i was working on it...
Good Luck, let me know how ya made out.
96 F150 XL,special
Air/PS/PB/AM-FM-Cass/
Light Package/300 I6/
5 SP Man/...
Nothing fancy just my little baby
