4Lo Problem
Old Jun 8, 2008 | 10:52 PM
daron's Avatar
4Lo Problem
I have a 1988 F150 Supercab 4x4... I am unable to engage the shifter into 4LO... I can get it into 4HI no problem...
I have acquired this truck from my brother... It has been sitting for a couple of years... Anybody with any answers?
Old Jun 9, 2008 | 01:46 PM
96BigRed's Avatar
my 91 will have the same problem if im not in just the right position try going back and forth in 4hi then trying to engage 4lo
Old Jun 9, 2008 | 05:57 PM
Colorado Osprey's Avatar
Lock hubs in after t-case is engaged.(this helps as there is no pressure from the front axle)
Slip transmission back and forth between reverse and 1st or drive and reverse while depress the t-case shifter into 4-Low.
Never seen one not go in without some persistance.
Old Jun 9, 2008 | 09:55 PM
daron's Avatar
4Lo Problem
thanks to Colorodo Osprey and 96 Big Red for replying... While waiting I soaked the heck out of the Transfer Case with a penetrating oil and after a couple of days I gave it a tap with a hammer, today the shifter engages into 4Lo smoothly with no problem. It must have been a little rusty from sitting for so long. Good to know that this sight is around for help on other problems that may come up.
Old Jun 10, 2008 | 05:44 PM
GTRider245's Avatar
9/10 of the time a T case shifting issue will be in the linkage. Glad you got it fixed and it wasnt something mor major.
Old Jun 12, 2008 | 01:41 PM
adrianspeeder's Avatar
Usually the pivot bolt binds up and ya gotta pull it apart to remove the rust.
This shifter style applies to the '88-'91 without the E4OD.
Adrianspeeder
