Heavy Duty Clutch?
Old Apr 6, 2008 | 04:17 PM
jeffronismo's Avatar
Heavy Duty Clutch?
Does anyone know where I can find a Heavy Duty clutch for my 92 F150 with the straight 6 and 5 spd tranny? My stock one has been going out on me for a little while and I went out mudding this weekend and ended up burning it up pretty good. I have only been able to find stock replacements but would like to get something better if possible. Thanks
Old Apr 6, 2008 | 05:01 PM
I have a heavy duty Brute Power on my V6, and if I had it to do over again, I'd go OEM. The thing chatters like crazy until I throw on a big load or hook up the trailer.
That said, Centerforce has clutches for your truck.
Old Apr 6, 2008 | 10:26 PM
tomcat6's Avatar
I have a centerforce dual friction for mine and it is way better than any clutch I ever had before. I do have the 5.0L, however, check out the centerforce site for more info.
Old Apr 7, 2008 | 01:20 AM
GTRider245's Avatar
Centerforce, Hayes and Borg Warner should all have an HD option for you.
Old Apr 7, 2008 | 10:04 PM
It looks like I will probably order the Centerforce Dual friction. Seems to be the best for the money. Thanks
Old Apr 8, 2008 | 11:22 PM
How do I know if I need to order the 10" or 11" clutch?
Old Apr 10, 2008 | 01:31 PM
I'd like to order it today, so any input on the correct size would be greatly appreciated.
Old Apr 10, 2008 | 01:59 PM
I'm going on a faint recollection, so don't take this to the bank, but I believe you can use *either*. I would highly recommend that you pull the flywheel and send it out to be bench ground as part of the job.
Old Apr 10, 2008 | 02:22 PM
Anybody know for sure?
I'm definately going to bring the flywheel to the machine shop before I put it back in.
