timing
Old Apr 9, 2008 | 11:30 PM
crashogden's Avatar
timing
i have a 95 f150 w/ the 5.0 i have about people retarting the timing and gaining more power from doing this. is this possible?
Old Apr 10, 2008 | 12:41 AM
Fleet Guy's Avatar
No, when you retard the timing the fuel does not get a chance to fully combust before it starts heading out the exhaust. You usually loose power and increase your hydrocarbon emisions.
Old Apr 10, 2008 | 01:01 AM
GTRider245's Avatar
What makes you think retarding the timing will give any improvements? Or are you just wanting to do this becuase you heard about it?
Old Apr 10, 2008 | 02:06 PM
Retarding the timing *can* reduce emissions under certain conditions, but it will definitely hurt both the performance and gas mileage. The *ONLY* reason to retard timing is to stop spark knock.
Old Apr 10, 2008 | 08:05 PM
bigbronc's Avatar
I think you got it backwards. Advancing the timing will give you more power. Your engine should already be 10 degrees btdc. I wouldn't advance it more than 13 degrees btdc. If you do, you will start to spark knock.
Old Apr 10, 2008 | 10:34 PM
crashogden's Avatar
well i guess i did hear wrong, thanks for the advice though
