air pump delete
Old Apr 6, 2007 | 04:41 PM
94f1504.9's Avatar
air pump delete
My uncle was telling me about deleting the airpump/smog pump on his 92 mustang 5.0. and i was wondering about doing the same on my 94 with the 300. what goes along with that and what the pump does. I dont have a yearly smog check up in the hick state of south dakota so that wont be a problem. but any help or information would be very appreciated. thanks Jake.
Old Apr 6, 2007 | 06:07 PM
JLF's Avatar
JLF
Well Jake, my recommendation is, if you aren't having trouble with your Smog pump, I'd leave it alone. It helps extend the life of your cat, it helps keep the air cleaner, and it saps very, very little power. At different times of engine operation, it will pump fresh air either (a) to the cat, (b) to the exhaust ports in heads, or (c) to a bypass muffler in the engine bay. My understanding is it does this to increase O2 in the exhaust stream & help unburned gas oxidize more fully & it helps the cat warm up quicker.
Having said that, I had 3 smog pump failures in less than 2 years so I eliminated mine completely by simply bypassing it with a shorter belt & installing a slightly larger idler pulley. It caused me no driveability problems at all, but it also did not improve the operation of my 351w. It just eliminated that terrible racket from a dying vane-type smog pump. Removing it and its plumbing freed up a tremendous amount of space on the right engine bank making plugs a lot easier to access. But you have to plug both the port to the heads and the line to the cat (or at least I did). The TAB & TAD (AIRB & AIRD in FoMoCo manual) can go as well as the tubing, one-way valves, & vacuum lines. Theres a lot of junk tied to the smog pump.
In short, it's pretty easy to do, but it isn't real eco-friendly (Al Gore will be ticked!)
Old Apr 6, 2007 | 06:21 PM
adrianspeeder's Avatar
Give a hoot, don't pollute...
Old Apr 6, 2007 | 07:09 PM
Steve83's Avatar
Keep everything working right & the truck will drive better, last longer, & cost you less to operate & maintain.
Old Apr 7, 2007 | 07:07 PM
beaverbanker's Avatar
Where the two pipes join off the manifolds, is this a cat? Or what?
Old Apr 7, 2007 | 09:34 PM
stopper's Avatar
Well, you could plum the output lines of the air pump into your intake and make a N**er rigged super charger. Has anyone tried that?
If my air pump EVER gives me any problems i'm not going to spend money to fix the darned thing i'm just going to buy a shorter belt
If it wasn't against the law to not have cats we could all buy trucks that came stock with a good sounding exhaust system. Not to mention the truck itself would be cheaper, too
Tree huggers
Old Apr 8, 2007 | 12:48 AM
Steve83's Avatar
bb
Yes.
stopper
Shouldn't that be "stooper"? That's the dumbest post I've read in a long time.
Old Apr 8, 2007 | 11:22 AM
JLF's Avatar
JLF
That wacky Steve, he's mighty sharp, but forebearance is NOT his forte. Guess it comes from reading the same old foolish posts again, and again, and . . .
Old Apr 8, 2007 | 02:09 PM
Ignoring your first line...
Originally Posted by stopper
Tree huggers
Yeah, who needs pollution control, cuz that smog builds character
I'm with Steve on this one.
Adrianspeeder
Old Apr 8, 2007 | 04:01 PM
How many miles will the cat's last without the smog pump?
(my pump packed, just don't really have the cash for a new one right now)
(i know i'm half high jacking this thread, but i don't think its worth a new one)
Old Apr 9, 2007 | 12:07 PM
Steve83's Avatar
bb
That's impossible to say, for any number of reasons. Fix it as soon as you can.
Old Sep 3, 2007 | 06:44 PM
onefastermonte8's Avatar
what size belt did you end up using
would a 302/ 351 have the same belt combination
i have a 97 f250 it is the same style as like a 95etc..
my smog pump went bad, and for hte time being, i need a shorter belt
what size belt are you guys using?
Old Sep 4, 2007 | 12:16 AM
Steve83's Avatar
No, a V8 doesn't use the same belt as an I6.
Old Sep 4, 2007 | 01:09 AM
KDPATe's Avatar
Ditched all of my emission gear off of the truck now that I'm running "P" heads but put back on a new hi-flow cat. Ran through emissions and passed with flying colors
Old Sep 4, 2007 | 06:04 PM
ratio411's Avatar
Just a heads up...
Cats need catalyst oxgen to burn.
If you disconnected your air pump, the soot is just building up in your cat.
It won't burn without clean air being pumped in.
Gonna stop up that new cat.
