gear change
Old Mar 11, 2007 | 10:10 AM
bpm4x4's Avatar
gear change
I read somewhere that I would need to take my truck in to get the speedometer reset after a gear change. I thought it worked off the speed sensor in the rear axle, am I wrong? is there a sensor on the tranny?
If the speedometer is the only thing that is going to be off, I may let that go. I just want to keep the computer happy.
93 F150 2wd E4OD
I think I am going to go to 3.55 gears (by doing a swap with a junkyard axle).
Brian
Old Mar 11, 2007 | 11:28 AM
Steve83's Avatar
Read this thread.
Old Mar 11, 2007 | 01:54 PM
bpm4x4's Avatar
Originally Posted by Steve83
OK I read it, and from what I am seeing, I only need to change the speedo setting if I change to a different size tire, but not if I change axle ratio. right??
Old Mar 11, 2007 | 04:08 PM
adrianspeeder's Avatar
Correct.
Adrianspeeder
Old Mar 11, 2007 | 10:08 PM
bpm4x4's Avatar
Originally Posted by adrianspeeder
Correct.
Adrianspeeder
Thank you
