Tire size question...
Old Sep 11, 2006 | 12:09 AM
ksubigbuck's Avatar
I am ready to replace the tires on my '90 f250 4X4 with BFG A/T's. Does anyone know how big of a tire I can stick on there? Stock size is 235/85/R16, and that is what I have on there right now. Speeder, if you are out there, I know you would probably know the answer. Any help would be appreciated, as well as tire reccommendations if you have any.
Thanks,
Hunter
Old Sep 11, 2006 | 09:33 PM
adrianspeeder's Avatar
The Broncos and F150s fit 33x12.5s no lift, but the 2 and 350s im not sure. Poke around IDI section at www.oilburners.net and see what they like for their trucks.
Adrianspeeder
Old Sep 11, 2006 | 10:05 PM
ksubigbuck's Avatar
Thanks for the link Adrianspeeder....I knew you would be able to point me in the right direction. I have done quite a few searches and haven't found much on the subject. I found the website for a tire dealer that said it would hold 305's with the original 16" wheels. How big is a 305 in relation to the 33" tire?
Thanks again for the help,
Hunter
Old Sep 16, 2006 | 02:20 PM
GTRider245's Avatar
Hunter
A 305 will be a little bit wider than a 33x12.50. As far as diameter, you need to know the other numbers to figure the size, since it is metric.
Old Sep 18, 2006 | 01:49 PM
tstjohn's Avatar
Probably talking 305/70/16?
that would be 33x12
Old Sep 18, 2006 | 08:56 PM
Also forgot on your body style you will have to remove your front bumper and space it out with some washers for clearance maybe. 92-96 for sure.
Adrianspeeder
Old Sep 19, 2006 | 12:03 AM
GTRider245's Avatar
Adrianspeeder
Or trim the inside corners. Either method will work fine. Knowing Adrian though, he would probably die before daring to cut into the factory bumpers.
