Truck whining under acceleration HELP!
Old Aug 4, 2006 | 02:38 PM
ksubigbuck's Avatar
My truck is making a whining noise under acceleration. It is a 1990 F250 with a 351 and an auto transmission. It sounds EXACTLY like a turbo diesel. That is the only way I know to describe the noise. Just like a turbo spooling up. Any idea what could be causing this? It doesn't do it when it is in neutral, so maybe it is the transmission. I dunno. Any help you could give me would be greatly appreciated.
Thanks,
Hunter
Old Aug 4, 2006 | 03:08 PM
beckerjs's Avatar
if it's hot there then it's the fan clutch engauged trying to cool the engine, it will go away
Old Aug 4, 2006 | 03:13 PM
ksubigbuck's Avatar
It is hot here, but I have a low temp thermostat and the engine doesn't get very warm. I wouldn't figure the fan would come on unless the engine was getting too hot. I hope you are right though.
Old Aug 4, 2006 | 03:42 PM
beckerjs's Avatar
try it in the morning, should be fine, also that noise goes away with some air flow on the fan
Old Aug 4, 2006 | 11:47 PM
ksubigbuck's Avatar
I think you are right beckerjs. It doesn't do it all the time. I am planning on replacing the stock fan with an electric fan anyway, I think that would take care of it.
Thanks,
Hunter
