Fast Idle
Old Feb 9, 2006 | 01:01 PM
sbcict's Avatar
Question Fast Idle
Setup of my problem: i was having stalling problems and like once before, removed the IAC and the throttle body and cleaned. Worked before. Also, i have a problem with piston blow-by to the point that the air cleaner box was soaking wet with oil. I attached a rubber hose to the outlet near the oil filler cap and let the hose fall into a catch can.
After doing all of this, i have the high idle problem. I have read several threads about high idle and its relationship to vacuum leaks. Looking for vacuum leaks, I sprayed carb cleaner over all joints with no affect on idle. Is the high idle because i have the oil breather hose going to an "open" can and not to the air cleaner box?
Old Feb 9, 2006 | 07:46 PM
lmd91343's Avatar
sbcict,
I don't know if carb cleaner will work. I've used brake cleaner.
The vacuum leaks I found were in the WHITE vacuum line to the defrost control door motor (near the radio antenna) and the gasket between the upper and lower intake manifolds. I found multiple breaks in the WHITE line.
-Lance
Old Feb 10, 2006 | 09:20 PM
Ford393's Avatar
Blow by
Have fun. I rebuilt a 91 Bronco because of that. It seemed to be a good excuse to do it. Wife had no clue what I was doing.
