almost over heating:
Old Sep 2, 2003 | 02:08 AM
Pete95XL's Avatar
This started tonight, the needle stays in the normal range. The heat level rises during acceleration. It won't go higher at constant idle.
It goes to the A in "Normal" on the gauge.
I noticed it was low on coolant...topped her off and the level isn't going down.
My question is this. If the car is low on coolant. It is running hotter. I add coolant on the way home. Is it possible that since it got to that heat level, it wouldn't go down untill it had a chance to completly go down to normal operating temp?
Turning the heater on doesn't affect it either.
Maybe it's a shot sensor..
Any help is great, thanks.
Pete
Old Sep 2, 2003 | 08:29 AM
PKRWUD's Avatar
Re: almost over heating:
No. Adding fluid would change the temp right away. If it didn't change, i'd replace the sender.
Take care,
~Chris
Old Sep 2, 2003 | 04:45 PM
Donate54's Avatar
when you filled it back up, did you put in purely coolant, or coolant/water mix?
Old Sep 3, 2003 | 02:43 AM
Pete95XL's Avatar
mix.... pure coolant would be bad. lol
