1994 f150 stalls when on gas
Old 07-28-2003, 09:00 PM
disbudz4u's Avatar
My 1994 f150 4x4 5.0 stalls big time when i try to press the gas, it doesn't die but you can hear the intake drawing in air. It can idle for days, but stalls when on the gas in park,reverse,drive,neutral.
Any Help?
Old 07-28-2003, 09:53 PM
inski21's Avatar
is it idling high?
Old 07-29-2003, 01:24 AM
disbudz4u's Avatar
No it doesn't idle high. But I noticed that the exhaust gas is not flowing as it should from the tailpipes.
Old 07-29-2003, 05:55 AM
PKRWUD's Avatar
Your cats are clogged.
Old 07-29-2003, 11:36 AM
Donate54's Avatar
i agree, have your cats tested , theyre most likely clogged
Old 07-29-2003, 01:24 PM
mxhotshot's Avatar
just pull the O2 sensor, and it if runs then you know your problem. the hole from the O2 bung will let enough flow out to let you know what is up.
Old 07-30-2003, 01:56 AM
disbudz4u's Avatar
Thanks guys for the help, anyway today i decided that the cat's gotta go bye bye. Put in some straight pipe where the cat was and the old ford rides again. Took me about half a day to complete but well worth it.
Dustin
Quick Reply: 1994 f150 stalls when on gas
