Converting my F150 into an off roader
Listen to trimble. That being a 97 Will have torsen bars not a coil over susp. like in the 04and newer truck. I'd say go body lift cause with body lift you can fit 35's easy. And you can also fit 35 with a 4or6 in susp. lift but that will be out of your range. Size of the tire is what gives the real ground clerance not the lift. For the winch you will need something at least 10Kor more. Weather it has cable or rope is a personal pref. not a need.
