4H to 2H violent shift in cold weather.
Old 03-15-2022, 07:09 PM
Chubet's Avatar
I just got my 2016 XLT back from the dealership which found no issues with the 4H back to 2H shift. Last week, when I attempted to shift back to 2H from 4H, it took 5-10 seconds and the shift was violent. I repeated this several times to confirm that there was an issue. I took it to the dealership who were unable to repeat the condition, the only variable that I can see is that it is 40 degrees warmer. Has anyone else experienced this condition? I believe something is sluggish in the cold, shift motor or actuators. Suggestions?
Thanks, Steve
Old 03-16-2022, 11:22 AM
Thanks, Steve
Hello! Please send a private message to us with your VIN and the name & location of your Ford dealership, along with some more details about your situation. I’d be happy to assist you. Thanks!
The following users liked this post:
Old 04-11-2022, 11:20 AM
tbear853's Avatar
Thanks, Steve
Were you on hard surface or pavement when this happened? If so, best to stop asap on hard pavement, back up a few feet even after you switch back to 2wd ... to ease the pressure on the gears that is maybe holding them engaged. I know that it's sliders with dog teeth but the pressure is there. With a manual transmission, you depress the clutch to relieve the pressures before shifting for the same reason.
Quick Reply: 4H to 2H violent shift in cold weather.
