Cracked extension housing
Drive shaft broke
My driveshaft
recent snapped in half and took out the transfer case housing. I have replaced the housing and the driveshaft. Now there is a vibration. Looking further into it I’ve noticed that the transmission extension housing is
also cracked between the transfer case and transmission. Ordered a new one already. Would this cause my vibration and can I replace this part. It’s a 2007 f150 xlt with 89000 miles on it.
please help.
please help.
Kitchenboys, welcome to the forum. I merged your two threads because we've found that multiple threads on a common topic lead to confusing responses that can waste your time or cost you money. I edited your first post to add the details left out of it and then tried to clean up the thread. If I've caused confusion, please add any further information you think would help.
- Jack
- Jack
When you say took out the housing. Do you mean the rear piece where the drive shaft slides into or the main transfer case housing itself?
The vibration could be from that the cracked housing. It may just be the driveshaft needs to be rotated 180 degrees at the rear end. Did you check the transfer case output shaft to see if it's bent or has any play?
