07 f150 wheel bearing or cv joint bad?
Old 07-14-2014, 10:50 PM
oldtruckluvr's Avatar
My father in law has an 07 f150 4x4 with 5.4. Recently he noticed it making a dull grinding noise when turning. There is no clicking or popping, just a dull grinding that is very noticeable. Only makes the sounds when turning though. Would this be a cv joint going bad or a wheel bearing. what are some good ways to determine what it could be? thanks again for all the help
Old 07-14-2014, 11:17 PM
Simply67X's Avatar
Sounds like it could be a hub. Has he grabbed the CV axle and checked it for excessive play?
Old 07-15-2014, 08:44 AM
i am going to look at it today. So, I just grab the cv axle and shake it to see if there is excess play? do I do that with the front end off the ground or on the ground. thanks!!
Old 07-15-2014, 10:25 AM
greentitan05's Avatar
When you do it also look real close between the flaps of the cv. Some people mistake a bad cv axle for a wheel bearing because they don't see the tears unless they take the cv axle off and fully extend it.
Old 07-15-2014, 05:42 PM
Simply67X's Avatar
On ground- thinking of the obvious things, checking for a broken axle joint. I had a broken one a while back and it wasn't exactly letting itself be known. I wiggled that thing and sure enough...
Quick Reply: 07 f150 wheel bearing or cv joint bad?
