Truck will not start
Old Feb 15, 2014 | 11:25 AM
Transplant's Avatar
Hilarious! I just posted about spark plugs and after the suggestion of buying a lisle tool I found a used one close by...started the truck to go get it, put it in gear and the truck died.
2005 F150 5.4L
fuse 34 is good
12Vdc at the fuse
no sound from the fuel pump
Is it true:
that the Fuel Relay is not serviceable on an '05?
there is a TSB on the Fuel Pump Driver Module?
Thanks!
Old Feb 15, 2014 | 11:34 AM
MGDfan's Avatar
2005 F150 5.4L
fuse 34 is good
12Vdc at the fuse
Is it true:
Thanks!
Hi.
Drop the spare, locate the FPDM, remove it from the frame crossmember and inspect it. If it even looks corroded in any way, replace it ASAP.
Several sources - MC @ dealer, local parts stores ( Dorman make a replacement unit )
How-To: https://www.f150online.com/forums/ar...placement.html
Ensure standoffs are used.
good luck
MGD
Old Feb 15, 2014 | 09:53 PM
Transplant's Avatar
Looked at the FPDM and couldn't believe how corroded it was. Replaced it and now the truck runs, thanks!
Old Feb 15, 2014 | 10:06 PM
Excellent diagnosis!
