Need help with output shaft bearing replacement
The transfer case is leaking on my 98 f150 4x4 on the rear output shaft and the seal looks easy enough to replace just have to drop the driveshaft
But how do I replace the bearing? It's the transfer case rear output shaft bearing if I'm not mistaken. There is a some play in it and vibration when driving.
