Longer driveshaft questions...
Old Oct 13, 2010 | 05:45 PM
Stu486's Avatar
ok, so i searched and searched and found nothing but jokes about makeing your shaft longer..... question is, with a 6" will i need to do anything to the rear driveshaft. In my searches i found that front need to be reclocked and balanced..?? not really up on what i would need to do with a 6" lift. Thanks in advance
Old Oct 13, 2010 | 06:29 PM
rivydzl's Avatar
I went a year with my stock driveshaft running 6" of lift and had no issues. I went a little bigger later on so I went ahead and got driveshaft spacers, a way cheaper alternative to getting a custom driveshaft. Of course, stupid me, I went ahead and got an aluminum driveshaft anyway (rear only). It was the only thing I hadn't modified powertrain wise. Since I am pushing a lot of weight and once or twice a year I like driving stupid (Glamis, Big Bear) I went ahead and made the upgrade roughly 2 months ago. No problems yet but I have yet to put it through anything but a little bit of mud, nothing serious. At least not powertrain wise. My truck always has a list of moderate issues but the driveshaft is great although it's definitely not needed IMO. See how far your driveshaft sticks out. If it seems like a lot and makes you uncomfortable, just get a spacer. Nice truck btw, I'm lovin the do it yourself blackout process!
Old Oct 13, 2010 | 07:37 PM
Stu486's Avatar
Thanks for the input and the compliments i keep going over this in my head about 4" would be simple...but then i know i will regret not going a little bit higher. I know i know..i could always get a BL but why not just get what i want now. i just dont want the 6" to become a headache...if it even will. guess i gotta think
Old Oct 18, 2010 | 08:31 AM
rebelangler's Avatar
i run a 6" lift with stock driveshafts and have yet to have a problem..08 fx4....53000 miles and i travel alot..like said above..if you feel uncomfortable get a spacer..
my .02
brian
Old Oct 27, 2010 | 12:48 AM
m8214m's Avatar
driveshaft spacer
I have a 2wd 2000 f150 with 4 inch blocks and 2 inch AAL I want to go higher where can I get a driveshaft spacer
