My truck rides sideways
Hey guys,
My truck (07 4x4 supercab) seems to have a sidestep (dogtailing) when it goes down the road its very noticeable the rear axle is 2 to 3" set to the right so the truck goes down the road sideways. Been to ford twice and they don't seem to want to notice that it is there. It drives straight when I let go of the stereing wheel and there is no uneven wear of tires (My truck has been through two sets though in 32,000 miles) What can I do that would prove to them its there or what do you think is the problem why its doing this??
Thanks a million!!
-Chris
Thanks a million!!
-Chris
I'm going to do a few measurements than that's a very good point
Yup my truck seems to eat up the fronts really quick the two outer edges correct pressure and all with steady rotation...... i do drive quite aggressively though
How's your alignment? I usually see them chevys and gmcs riding sideways down the highway.
Mine doesn't drive sideways but I feel like the rear axle might be shifted a little because the rear wheels aren't even with the truck bed, and the right side gap is much smaller, I believe it's dog tracking? Sorry to thread jack
go to a body shop and have them check the frame, they can tell if it's bent / not square,if there's a problem then if it's still under warrenty take it to the stealership and show them the shop report - fight to get re-embersed for the independent shop cost's
i had i problem with my 87 f150 brand new pulling to the right when braking - they repeatedly tore down the brakes and claimed they checked the front end - i ended up going to an independent shop and in 5 min they had found that the tie-rod ends were bad - only 5k miles, i went back to the dealer and fought to get my money back (i had the shop fix it)
If he's running the stock hancook dynapro A/S then that is what almost what I got out of them. 18K and I got new tires. It wasn't wear from the leveling kit because the backs and fronts looked the same and I wasn't terribly hard on them. They wouldn't have been street legal by 20K but I changed early because they were sliding all over the place. Even a drizzle could be dangerous in the city driving.
quoted for truth.
my 06 F-150 had 20K miles on it when the factory hancook tires 225/70/17's and by 23K they where near bald. so I burnt them up and bought new tires.
Since it's 4x4 are you sure it's not because Ford made them stick out to grip when the front tires are not gripping?
My 97 All Wheel Drive Explorer was like that. The front wheels sat out just a tad more then the rears. I took it all over town and got the same answer. Even called Ford and they said it was because it wouldn't track in the same tracks and less likely to get stuck..
