Front drive shaft slop 2007 f150
I pulled my wheel today to check the wear on my brake pads and I noticed that the drive shaft has a significant amount of play in it. I have attached a video so you can see what I am talking about.
I have had other 4x4's (Toyota, Chevy,) but none have ever had slop like this in the drive shaft.
Is this normal for Ford trucks or is there something wrong here.
Thanks for your input.
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/5l3dwYt7F3g?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/5l3dwYt7F3g?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Yes, the CV shaft from the front Diff to the wheel. If I grab that shaft I can turn it back and forth at the wheel. No up and down play (like a bad u-joint) it turns inside the hub, maybe 20 degrees of play? I think it may be normal for a Ford but just want to make sure. On my other vehicals I was never able to turn the shaft at all so I want to make sure.
The play appears to be inside the wheel hub?
Im not sure then I know your gonna have a little bit of play i the differntial but with the tire on and on the ground you shouldnt be able to turn it or i wouldnt thank, unless its something in the newer style 4x4 system i know hte older style TTB and Solid axle you cant do that...
Hey, graphite, just thought I would chime since I had my wheel off to address my IWE/hub and or lower balljoint issues. I have the same play in mine as in your video, not sure if that is normal or not, but I'm thinking that it is, I seem to recall it always doing that.
Mine does the same thing; I am thinking that is part of what I here clicking on when switching into 4wd (when it works!). I think that goes into what is called the actuator on the hub. That part will break long before the shaft; I broke one just by slowly hopping a curb at a bad angle.
Are your other trucks manual or electronic switching?
Yea man your fine. Thats perfectly normal. Your truck locks the hubs when your truck is shut off so its not going to rotate freely. However, when you start your truck, they will unlock and rotate freely. I tried to turn mine on my 04 and they do the same thing, they have a little play.
