Super charger sound
Old 08-11-2010, 09:57 PM
red06's Avatar
Super charger sound
Hello all, I have a 06 4x4 with the 5.4. Some one pointed out to me that my truck makes a whining noise at higher rpms when the truck is in lower gears kind of like a super charger. It does it no matter if it is in gear or not you can also make it do it in park if you hit a certain rpm. Some one suggested that it might need power stearing fluid or a pump. I checked the fluid level and it's fine. If its the pump wouldn't I start to see leaks or notice something wrong in the stearing? None of which is happening. The truck runs and drives fine. Could it be a glazed over drive belt making that noise?
Old 08-13-2010, 01:51 AM
MmmBuckles's Avatar
sounds like a torque converter.
Old 08-13-2010, 06:51 PM
jhunt47's Avatar
ive seen alot of alternator bearings going bad on these trucks
Old 08-16-2010, 08:50 PM
red06's Avatar
Thanks guys I guess it's off to the dealer.
Old 08-16-2010, 11:33 PM
mSaLL150's Avatar
Have you had any audio equipment installed recently like an Amplifier? Ground loops can cause alternator whine through the speakers, it sounds like a supercharger and exactly like what you describe.
Old 08-17-2010, 06:18 PM
katoomryder's Avatar
You could try removing the serpentine belt and runnin gthe truck for a couple of seconds. if the sound is gone, you've got a bearing going on something the belt turns (alternator, ac motor, tensioner pulley)
Old 08-17-2010, 10:03 PM
jemckinney's Avatar
Mine did that with my cold air intake but it's funny you say it sounds like a supercharger because the sound went away when I took off the CAI and added the supercharger. Not sure if you have a cold air intake on your truck?
Old 08-18-2010, 12:44 PM
glc is offline
Throttle body spacers whistle too.
Old 08-23-2010, 03:58 PM
citation550's Avatar
Same problem in my truck. Ended up being the alternator
Old 08-25-2010, 10:39 AM
FX4NUT's Avatar
super charger sound
red06,
you could have a vacuum leak. It probably sounds like a long little whining, faint but still noticible. Check the EGR valve hoses and check for loose or cracked hoses. Also those little plastic hose joints tend to crack and give you a leak. Let me know how it goes
Old 08-25-2010, 04:45 PM
red06's Avatar
Super charger sounds diagnosis
Hi guys thanks for all of your suggestions for fixing my 06. I just returned from the dealer and it turned out to be both idler pulleys that were making all that noise. Thanks again, Red06
Old 08-28-2010, 02:29 AM
James Hopes's Avatar
Just don't care for the way superchargers sound at all. I think the kb one would make me not want to drive fast. Superchargers are fun but the sound not so much.
Quick Reply: Super charger sound
