gear install kits, arg...I have no clue what I need
Okay wanna do my gears...but now I was told I need install kits as well as the gears in parts alone would be like 700 or more for the overhaul kits + the gears....SO what install kit do I use the minor install kits or the middle install kits or the complet overhaul kits
simple fact is it aint gonna be cheap. im looking at 800 installed for mine. that will include the gears, master install kir (recommended by shop) and then the inner bearings and other parts that will need to be replaced.
now that price may come down due to the condition inside there but till its open theres no telling. talk to the shop thats gonna be doing your install. i was gonna get my ring and pinion seperate and the install kit but once its all said and done it comes out just about the same so i went with the shop to save frustration
^^He is right. As a reference..
When I got my gears done I had 175k on my rear end. At that point I needed new bearings pretty much all around as well as seals etc. My axle shafts were all good, and I doubt you would need new ones because they dont usually mess up. The shop I got my my truck re-geared at only charged me $90 for all the bearings and what not so I would wait on install kits and let the shop handle it. I made out paying $648 for my re-gear
i paid $282 for my yukon 4.88s from completeoffroad.com and i paid about $150 for the master install kit that came with all the bearings u need and all the shims plus the marking paint and diff cover gasket from completeoffroad.com
If you need absolutely no parts and your axle is in good shape, you can get away with ring & pinion and a crush sleeve. That's the bare minimum and I've gone that route with zero problems. I haven't done my front axle yet but plan on doing by this winter before snowfall and that's what I'll be buying.
Here's what i would buy if i had to do a gear swap:
http://cgi.ebay.com/ebaymotors/ws/eB...m=230394011332
http://cgi.ebay.com/ebaymotors/ws/eB...m=260551075246
http://cgi.ebay.com/ebaymotors/ws/eB...m=280463388704
75W-90 Gear Oil in front axle (as recommended by the ford f-150 owner manual)
75W-140 Gear Oil in Rear axle (as recommended by the ford f-150 owner manual)
75W-140 Gear Oil in Rear axle (as recommended by the ford f-150 owner manual).
Thanks for the info !
You havent does your front axle yet? isnt that a big deal cuz the front and rear will inturn bind the drivetrain.
Well motive gears any good heard they have different levels of quality, and that 8.8 cover wont work because the stock cover hooks up to a bushing to mount the axle.
I have motive 4:10s and didnt have any trouble with the 8.8 housing cover! Honestly if the diffs are clean and show no signs of bad wear and tear, you do not need anything but the gears and some elbow grease! Take the pinion gears to a machine shop to have them remove the bearings and put them on the new pinions. All others stock parts such as the crush sleve, shims, etc will works just as good as any install kit. OH! Make sure you keep track of the shims and remember exactly where they go!
