8.8 locker problem
8.8 locker problem
I can't get the pin out of the locker the pin hits the ring gear. do I have to loosen the ring gear to get it out? To pull the clips on the axels. Thx
you should honestly be able to pull it out with your fingers, you may try a set of channel locks and a terry cloth to keep from marring the surface. otherwise you can try grinding the teeth down just enough to clear.
If it's the ford 8.8 trac loc there is a reeeeely good set of instructions at this site
http://www.angelfire.com/theforce/5o...5ohtech001.htm
my son is using it right now for his 85 Bronco, it's awsom! Oh and he got a good deal on the gears and set up kit at summit.
Send me your email and I can send it to you just got a new kodak camara and trying to figure it out. Thx Alot Mine is Badtoyz88@aol.com
[IMG]100_0259.jpg[/IMG] Here some pics.
