Drivetrain vibration in 99 Ford 150
Add one more to the list. Dealer had it for three weeks while fixing it. Then wanted me to pay $8 when they washed it!
Here's what they did:
Reindex, balance tires, no change.
Replaced motor mounts, no change.
Isolated exhaust(?), no change.
Replaced pinion gear, no change.
Replaced pinion gear again, grinding noise.
Replaced rear axle with factory new one, fixed?
While driving home, there was the same old vibration. Happens around 1700-1900 RPM. Taking it back next week to have the Service Rep drive it. Will let you know if they find anything.
gwallace,
I've got a vibration at 1750 rpm +- 25. It's independent of speed, but engine has to be under load. The dealer replaced the exhaust on mine, no change/charge. I've heard something about the output shaft of the transfer case (if you've got 4x4). Who knows?
'99 Lariat Supercab 4x4 SS
5.4L, 3.73 Diff (9.75" LSD Rear, 8.8" Front)
ORP: Skid Plates, LT265/70R17 GY Wrang. AT/S
Group III towing: HD Electrical/Cooling, GVWR 6500# (Extra leaf spring).
Step Bars
4W Disc anti-lock brakes
K&N filter
Stock Items That Differ Across F150s: Steel Driveshaft, Oil filter bolted to engine w/ drip guard, 4R70W transmission.
Step Bars
K&N filter
For those that complained about the vibrating gas pedal there's a fix out for that too. I had it done to mine and it worked. The dealer has a SSB (not sure of the number) to reroute the accelerator cable away from the power steering resevoir. That cured it. Bob
99 EB Expedition 5.4L with all the perks,3.73 LS,Heated Mirrors and Seats. Everything but sun-roof. Rhino Step Bar, Ford Bug Shield,More to come...
michael_hovis and others with 4x4-
My '97 has a harmonic balancer or something similar on the output shaft of the transfer case - just in front of the u joint. It is about 9" to 10" in diameter and about 1" thick. The reason I noticed it was because it separated from the rubber spacer on the inside diameter and then it moved down the driveshaft and made a ringing sound as the drive shaft rotated. This was replaced under warrenty and has since given me no trouble. Have they eliminated this balancer on later models? Maybe this is the cure?
Mine: FOR SALE SOON...1997 F150, XLT, SC, Oxford white/maroon 60/40 cloth, 4x4 ORP, 4.6L, 3.55LS, 17" ORP wheels w/GY AT/S LT265/70/17, auto, 6 CD,Towing package, alarm, Rhino grill guard w/PICCA lights, dual exhaust. Bought new June '96
Wife: '99Explorer Limited,pearl white/tan leather,4.0L,4:10LS,CD,sunroof,towing pkg.,alarm. Bought new Sept. 1999
Next: 2001 F150 XLT SuperCrew, 5.4L, 4x4,3:55LS,tow pkg. etc.......
Previous: '65 Mustang 289 HP, '70 Chevelle SS 396, '70 Vette Conv. 350/350, '74 Vette TTop, '79 Blazer, '89 TBird Super Coupe 3.8L SuperCharged, '93 Explorer 4.0L
Expy Bob:
How was the accelerator cable relocated? I have the gas pedal buzz at 1750 RPM, and would like to re-route it myself, if possible. Any details would be appreciated..........
2000 XLT Black Sport, Flareside, 2WD, Ext. Cab, 5.4L Auto. Other factory options: 3.55 LS, Class III tow, 6-way Captains chairs w/CD changer, Remote entry , and Slider window.
Mods: Undercoat, window tint, headlight & tail light covers, removed "Sport" decals, upgraded Triton tailgate emblem, Linex spray-in bedliner, and an ARE LSII lid.
Wish list: Flowmaster duals, K&N FIPK or Velocity Tube, and a Belltech 3/4 drop.
Check out more pics at: http://home.columbus.rr.com/selva1/f150.html
[This message has been edited by selva1 (edited 03-08-2000).]
TSB 99108 was issued for this. From what I understand they remove the cable from the P/S resevoir clamp and cover it with rubber insulation. It worked for me. I hope this helps.---Bob
I also had vibration problem with my 2000 4.6 at about 65mph at 1700rpm. I just replaced the stock exhaust with a flowmaster system. I no longer have the vibration I onced felt. I can only contribute the problem with the stock exhaust system.
2000 F-150 XLT SuperCab,Silver,sport package,4x2,4.6 Triton,3.55 LS,tow package,power seat,single CD,sliding rear window,keyless entry
My 99 150 vibrated @ 43 mph like all four tires were out of round. Dealer did all mentioned fixes. Not until factory svc bulletin/modification came to dealer could they stop it. It consisted of a counter balance/dampener installed inside the rear bumper. Stopped 99% of vibe. (I also had a bad "fluid driveshaft" they replaced it on my first visit. Contact my dealer:
MARTIN FAMILY FORD
P.O. Box 2599
Morganton, NC 28655
1-800-951-2277
They fixed mine and can probably give you the bulletin #. Remember, the dealer didn't build the truck, "engineers" did, and the mechanics/service mgrs shouldn't have to take crap for those mfg problems. Good luck.
MARTIN FAMILY FORD
P.O. Box 2599
Morganton, NC 28655
1-800-951-2277
Bob, it was installed inside rear bumper, I checked. I'm thinking since truck bed is now fiberglass, there is some kind of wind harmonics/wind lift?? I still have just a tad of vibe @ 40-45 mph. How about yours?
I have a '99 w/4.6, AT, LSD(3.55) stepside,
extended cab XLT, Class III tow pkg w/hvy duty shocks.
Sorry, Bob.....
the d/shaft is filled with a viscous fluid of some kind. Mine vibed @ 63mph out of the gate. Dealer indexed/rotated tires, etc.
By the way, I took the mechanic for a ride in one of their trucks on the lot and it vibed @ 43-45mph just like mine did! Dealers should have TSB showing inst loc for dampener. Larry
Larrym67
Even with the new drive shaft and damper on the rear axle it still has a little low pitched rumble or booming at 70-75 MPH. Funny, I get a similar noise right at 63MPH. I didn't know there was fluid in there. What happens if it gets low???
Thanks for the reply---Bob
Bob-check above post silversport mentioned exhaust, they do get harmonic resonance if loose I've noticed, requiring exhaust dampener. As to low D/shaft fluid, it's supposed to be a sealed unit. Don't know where they'd put a dipstick. LOL
Seriously tho, this has to be an engineering design flaw/screw-up cause I've NEVER heard of these kinds of problems until fiberglass bed skins were introduced, as well as "hubcentric" design wheels. What the heck was wrong with the century-old design? Progress--ain't it grand? Larry
Well here is my update. Dealer had it for another 13 days. They replaced the accelerator cable and said everything was OK. It was, for about 30 miles. Needless to say I'm not taking it back. Ford did offer up the extended warranty at no charge for all my troubles. BTW I forgot to mention that they had also replaced the driveshaft the first time around.
Lesson learned: if you think you have rear end troubles just complain about a vibrating gas pedal. Guess if my A/C starts having troubles I should say the tail gate is broke.
Larry, I agree that it isn't the dealer, mechanic or svc manager that caused the problem. But they are the ones that the paying customer has to work with to get a solution. All I know is I'm tired of making payments while my truck is in their garage instead of mine.
Where is that duct tape?
