Gearing question
Old Aug 9, 2009 | 05:33 PM
johnbaughman85's Avatar
Gearing question
ok i just put a 6in suspension lift with 35s. im gettting a gryphon programmer. i want new gears but they are exspensive. my truck is an 04 4x4. could i just regear the back now and regear the front later when i have the money.
Old Aug 9, 2009 | 06:16 PM
2002 wonderboy's Avatar
that is an option, but don't try and use 4wd while your truck is configured that way!!
Old Aug 9, 2009 | 11:47 PM
yeah i wouldnt use 4wd. i just wanted to know if that was a possible thing to do
Old Aug 10, 2009 | 01:41 PM
It's possible, but I'd recommend you find a way to completely disable 4wd engagement till you finish the job. One mistake and you will bind everything up. Do NOT get a rear gear set in a ratio that's not available for the 8.8 reverse cut front.
Old Aug 17, 2009 | 09:27 PM
yeah i think i would remove the front drive shaft. would that be a good idea. the switch for 4wd is so easy to do i would scared if someone accidently turned it.
Old Aug 18, 2009 | 01:06 AM
Hash278's Avatar
Just be extremely careful. There was a guy on here that gear his 4x4 that way and he engaged his truck one time and he had some pretty bad issues with it.
Old Aug 18, 2009 | 12:43 PM
I would remove the front driveshaft.
Old Aug 18, 2009 | 05:22 PM
bigdad8214's Avatar
I would think you'll will get a better deal for both and one time.
Old Aug 18, 2009 | 05:34 PM
i wouldnt be worried about me engaging the 4wd. i would be worried about someone else doing it. About how much does gearing the front and rear cost. i want 4.56's maybe. cause i got 35's but i eventually wanna go to 37's
Old Aug 18, 2009 | 05:59 PM
b2therad's Avatar
I would say around $1,500. Might end up being more if you do them individually. I think that 4:56's would be good for 37's, but thats just going off of my friends trucks that have that set-up. I have a buddy with an chevy 3500 with 4:88's(im pretty sure thats what they are) and 40's and he burns them out all the time.
Old Aug 18, 2009 | 06:13 PM
efuehrin's Avatar
I don't know how you engage the 04+'s but my 03 just has a little **** like the fan controller.
I just put some red electrical tape across it. Visual and Physical deterrent.
Old Aug 19, 2009 | 03:50 AM
Hash278's Avatar
Its the same on the NBS, the tape is a good idea.
Old Aug 19, 2009 | 12:42 PM
i agree the tape is a good idea. i think 4.56s would be the best for me. i dont plan on roasting my tires. they cost to much
Old Aug 19, 2009 | 10:32 PM
seclineman's Avatar
i think i payed $1600 for front and rear 4:56. i have 37's and can burn em off if need be.
