Take a look at these pics (rear end related)
I am no expert on rear ends but the leak at the driveshaft is the pinion seal leaking and the leak at the top I believe would be the rearend vent. Pinion seal is not a big job to fix. Not sure why the vent would be leaking unless it is plugged and you are building up pressure forcing lube out?? I've changed my pinion seal twice on my 97 not a big job.
I do believe that the lower leak is the Pinion Seal.
I believe however that the leak on the top of the diff is the diff cover gasket (easy fix). It wouldnt be too bad to go ahead and buy a gasket, pull the cover, clean the old gasket off the metal and apply the new one. This will also give you the chance to change the diff fluid, and inspect the inside.
Id also check the breather line, make sure its not kinked or blocked up in anyway. Its located on the axle tub and runs upward.
they are both pretty easy fixs grab a Hanes manual or chiltons and just follow the steps. They often give you more steps than really needed but if you follow them it will turn out right.
I believe the Diff cover just uses silicone for the gasket. That's all i have ever used.
Last time I changed the oil in my F250's rear I just used Blue goo....
Clean the cover and the back of the housing real good, put the silicone on the cover, making sure you seal around the bolt holes well, and lit it skin over for a little bit.
Then bolt the cover on, and fill 'er up.
