4X4 rear axle seals leaking
Hello, new to the forum. I recently bought a 2003 F150 4x4 140K miles (shes really clean), I installed some tires and it was brought to my attention that the rear seals were leaking. We pulled off the hub (all disc brakes, but the parking brake uses shoes inside the hub on this model) and grease was caked all over. Looks like the air vent tube/port on the top of the rear axle was clogged and caused the seal to blow. So I understand that the brakes, rotor, axles, and seals need to come out. Is there anything that needs to be done with the rear diffrential or gears back there? I think I can handle all the other stuff, but messing with ring and pinion gears makes me nervous. Any tips, ideas, or guides would be much appreciated. It feels good to be back in a truck again
If the vent was plugged the seals may still be good. Make sure the vent is free and clean up every thing and see if the leak comes back.
By the way you do not have to mess with the ring and pinion gears to take the axle out. You just have to remove the back cover, take out the locking bolt, pull the pinion shaft out, push in on the axles then remove the "C" clips and pull them out. There is nothing to set up.
