Some questions about what axle gears to use...
ok...here is what i have found that looks like what i am going to get
http://www.ringpinion.com/ProductDet...px?ProdID=1949
now i noticed that it says "A notched cross pin shaft is required for this gear set."
what does that mean?
also is this the gears for the front and back being that they are both 8.8?
the gears in the link will work on the REAR of the truck. but for the front you will need 4.88R because the front axle is REVERSE CUT (R)
haha i just posted the link to the reverse cut...after i posted the first link i scrolled down the list and saw the reverse ones...thats what i figured they were. Thanks
yea i know it wont be FAST but it will definetly be better than it is right now...it is sooooo slow!!
******: reverse cut = front (like trimble said )
The notched cross pin, most likely is referring to little cross pins that are located in the planetary gear set-up. I assume one needs to be notch for clearence. i haven't seen this before, and am simply assuming here. Thats the only thing I could think of that would be a "notched cross pin".
yup, I was right !!
http://broncograveyard.com/bronco/i-32308_froogle.htm
Its the pin going through, in the planetary gears. Needs to be notched for clearence. Plenty of places sell em.
come wheel with us !!
yup, I was right !!
yup, I was right !!
and dont worry about MM he's a highway queen, parking lot crawler
im sorry man i couldnt resist.
