Front end problems
Front end problems
I've been having problems with a grinding/popping noise coming from the front end during the last couple of months. I replaced both CV shafts and that seemed to keep the noise down for a bit but the noise is back stronger than ever. The noise is most noticable whem I'm accelerating but I can here it whem I'm driving and braking also. I finally had a chance to jump under the truck this morning and I may have found the problem.
The flanges that the CV shafts connect to have quite a bit of movement in them. They not only move up and down but in and out. I'm thinking I will be pulling the front end out sometime in the near future and have the problem fixed. Fixing the problem raises a few questions.
From the above description, what is a rough estimate to take care of the problem? Is a complete rebuild necessary? Would a junkyard be a valid option?
on
Sounds like the bearings in the axles. You won't really know till you pull it apart. Look up your Axle at http://www.car-part.com
Select Year = 2003 Select Make/Model = Ford Truck F150 Select Part = Axle Assy FR(4WD w. Housing)
You will want this axle;
exc. 7700 GVW; w/vacuum disconnect; 3.55 ratio Unless you have the 3.31:1 gears.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
on
On the passenger side you remove the 4 bolts holding the axle tube to the diff and the axle is held in by a C clip. On the driver side remove the diff cover and the axle is held in by a snap ring. The front axle assembly is heavy so get a jack and strap it to the jack then lower it.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
on
Originally Posted by dye7barrel
Doesn't sound like too bad of a job. I've been looking at replacement bearings for the axle and all the part stores list an inner and outer bearing. I figured the outer bearing goes in the end of the axle tube closest to the wheel. Not sure where the inner bearing goes. Any ideas?
JMC
Thanks JMC, that's exactly what I was looking for. I had a feeling the long shaft needed the inner bearing for stabilization. The diagrams make it look somewhat imtimidating with all the little parts. I guess I'll find out this weekend. I'll be sure to take some pictures and hopefully post them. Are there any other seals/bearings I should replace when I have the axle apart?
