wheel bearing installation...need advice and pointers!!!
So i have concluded that i need to replace one or both of my front wheel bearings on my 2000 F150 4X4 V6 in order to stop the loud humming noise coming from the front of my truck. I understand that if purchased from the parts store the hub and bearing assembly comes together in one kit. Does anyone have any advice or pointers on this process? Do i need to remove the axe shaft coming from the front diff? If so, how do i remove it? I know i can do it myself, i just need some additional pointers....Thanks!!
easy there bud there's actually nothing to it...
go get a chilton's book from autozone, a deadblow hammer, and a 1/5th of 100% southern comfort........
mix ingredients together in driveway and let stand trying to figure out what's going for about 3 hours.... finish and repeat as necessary
If you can do brakes, the hub is only one more nut and three more bolts. Pick up a replacement axle nut as the original is a one-time-use nut and should not be re-used.
You'll need a 38mm socket for the spindle nut, and IIRC the three bolts that hold the hub into the upright take a 19mm socket.
-Joe
-Joe
I have gotten the three bolts off for the hub, but it seems like the hub assembly is really on there. Should it just pop off? The axle is free from the hub but the hub is really attached (rusted) to the spindle. Once i get it off, does the new unit just slide back into the spindle and attached with the three bolts? Can i beat on it ?? Do i need any type of puller?
I have taken the spindle nut off, and I know that the axle itself is free from the hub because i can push in on it and it moves the axle in toward the diff. I am having a hard time getting the hub assembly off of the spindle. I have sprayed it with PB blaster and beat on it with a hammer. I will try a bigger hammer or take the spindle off like you did.....The truck has over 160,000 miles so it might be a little stubborn....Do i need to pack the new bearing assembly with grease?
