New Gears? Lifted 2WD
Old 12-02-2007, 12:30 AM
bluedevil72's Avatar
'97 2WD with 7.5" fabtech lift went from stock 275 70's to 35" tires. do i need new gears in the rear, will stock do or will they eventually have trouble?
Old 12-02-2007, 11:46 AM
glc is offline
How does it perform now? If you are satisfied, no NEED to regear.
Old 12-02-2007, 11:08 PM
thanks, nothing at all wrong now.fells like it rides a little rough low in a high gear,sorta feels like it's bouncing a little when ur rpm's are real low in a high gear.on a highmay as soon as it shifts into fourth or fith and the rpm's drop down to bout 1,000 to 1,500 wich is where i like it,so it will save gas, i can't run it there cause of that bouncing like crap, i have to run it at or a little over 2,000. people just told me that i might need some, just was checking. if i did get 4:11 or 4:56 would anything change?this is no major problem at all. will it become one?is it wearing the gears down there?
Old 12-02-2007, 11:30 PM
_cashel's Avatar
what gears are you running now? With 35's I wouldn't say it's necessary, but I'd recommend it.
Old 12-02-2007, 11:48 PM
stock whatevr that it. 3 something.
Old 12-02-2007, 11:52 PM
whatever that is? i know it's 3 something. i saw a guide thing in a manuel and it said to change em when bigger tires it had recommended gear sizes for 35's for everyday driving, highway driving, and towing.the lowest for everyday driving was 4:11 and highway was 4:56? if i did regear, what kind of differences would i notice?
Old 12-03-2007, 08:45 AM
ChrisT's Avatar
The difference you will notice has a lot to do with your current ratio. Look at your door jamb for your axle code and then search on this site to reference which configuration your truck has. I went from my stock 3.55LS (axle code H9) to 4.56LS and it was a noticeable, good change for what I was wanting for my truck.
Old 12-03-2007, 11:44 AM
_cashel's Avatar
you more than likely have 3.55 or 3.73 w/ or w/o a limited slip stock. If you upgrade your gears you'd basically gain more low end power but lose top end speed.
Old 12-03-2007, 12:27 PM
jackedup4x2's Avatar
gearz
i have 35's with stock gears...it was recommended to me to run 4.88 gears, but i have a v6 so it might be different with a v8...more like 4.56
Old 12-04-2007, 08:45 PM
i know now, it want hurt it at all the worst it can do is help, esp. after today on my way to school, i was goin up a hill and i kicked it in to get up it and it slipped just a little.
Old 12-05-2007, 09:04 PM
Jordan not Mike's Avatar
Ummm...no. You won't lose top-end speed.
You'll be turning slightly higher rpm at any given speed, but these trucks are geared so tall that you'll never run out of rpm no matter what gears you put in, so there's no way you'll limit your top speed.
I couldn't turn redline in top gear and I had a supercharger.
Another member here, with 29-inch tires and a built motor, ran over 150mph with 4.10s.
Quick Reply: New Gears? Lifted 2WD
