4.10's or 4.55's gears?
Originally Posted by GerRod
You were right going with the 4.10s...obviously, if you're lowering it, you can't run tires big enough to justify 4.56 gears...
Are you running the 4.10's also? How do you like them? What gear brand did you go with? Problems, nuisances? Are you burning up tires?
Well if you add larger tires and want to keep your gearing close to the same use this formula.
Figuring gear ratio with different size tires.
Divide the old tire diameter by the new tire diameter and then multiply by the current ratio. So a stock 87 5.0 GT tire is 225/60/15 or 25.63 diameter and say we put a 255/60/15 or 27.04 on.So 25.63 divided by 27.04=.9461 then multiply by the stock 2.73 gear and get 2.588 which is definitley not a drag gear.
This is a good site for comparing tire sizes http://www.1010tires.com/TireSizeCalculator.asp .
