Silicone or Gasket for Differential Cover
Old May 16, 2007 | 03:07 PM
peacjt's Avatar
Axle Seals are ready for replacement on 8.8 Limited Slip. I've always used a gasket and silicone, but was wondering if Silicone only should be used. Which is better? Any suggestions??
Old May 16, 2007 | 03:46 PM
keith97xlt's Avatar
ive never done a differential but ive always used silicone and gasket on tranny pans. never had a leak. tranny fluid will leak easier i would think becaause its much thinner.
Old May 17, 2007 | 06:48 PM
peacjt's Avatar
I'm going with silicone only, being that this is the way it came from the factory. Good and clean, 1/8" bead all the way around. Thanks
Old May 17, 2007 | 07:06 PM
Kevin24's Avatar
Hey make sure you go around every bolt hole in addition to the 1/8 bead around the cover Also try to find a good oil resistant silicone and follow the assembly cure time on the silicone
Old May 17, 2007 | 07:37 PM
rogue1's Avatar
The " right stuff "
I can't figure out why I never hear anyone here talk about using " The Right Stuff " NAPA sells it, along now with an application gun, since the cheese whizz style can is history. Once you use this stuff as a gasket maker, you'll never go back to straight silicone. In this part of the country, it's spoken of like a religious thing.
Old May 17, 2007 | 08:01 PM
BlueScrew4.6's Avatar
Can't go wrong with Permatex Black. I used that when i had my 8.8 and it sealed it up like a champ. Like Kevin24 said, make sure to go around each bolt hole in addition to a solid 1/8th inch wide bead around the pumpkin. Better safe than sorry.
Old May 19, 2007 | 03:12 PM
peacjt's Avatar
Used the Ultra Black. So far so good.
Old May 19, 2007 | 08:21 PM
BlueOvalFitter's Avatar
Thumbs up
Gasket and a very little bit of RTV.
Old May 20, 2007 | 01:33 AM
way fast witey's Avatar
red rtv is great for just about everything. with or without a gasket works great.
