4x4 solenoid question??// problem?????
Old 02-20-2007, 02:15 PM
cfl4rat's Avatar
i'll make this short. 4x4 light is comming on, front drive shaft turns, but front tires don't...i have vacuum and power going to the solenoid's but i do not have vacuum at the front diff. i seperated the vacuum lines their in the fender well and no vacuum their so i checked the lines and they were ok. i got under the truck and pushed the actuator arm in and the 4x4 worked i can even turn it off at the dash but to get it to work again i have to get under their and push the actuctor shaft back in.... i can turn it off but not on?? but i don't have vacuum???? i don't get it!!!!!!!........... sorry so long
Old 02-20-2007, 03:52 PM
GIJoeCam's Avatar
It's apparently getting intermittnet vacuum from the solenoids to the vacuum motor (center axle disconnect). Double-check the solenoids... I suspect one is (or both of them are) sticking.
-Joe
Old 02-20-2007, 03:59 PM
cfl4rat's Avatar
-Joe
i popped the top caps off the solenoids it looked clean inside all i could see was a little yellow foam washer. is their a way to "un-stick" them? and with the cap off are they supposed to do anything, so i can tell if their working? thanks!!
Old 02-20-2007, 04:57 PM
kingfish51's Avatar
Remember one solenoid is to engage, and the other to disengage. They should never have vacuum to the diff at the same time.
Old 02-20-2007, 05:09 PM
GIJoeCam's Avatar
Good question: I dunno. I admit I've never had one apart before. May have to add that to the list if I ever find one in a local pick-n-pull yard.
-Joe
Old 02-24-2007, 02:25 PM
bullseye670's Avatar
I think its obvious that the vacumm silonoid to engauge the 4x4 is not working.
Old 02-24-2007, 04:02 PM
GIJoeCam's Avatar
Not necessarily.. the disengage solenoid could be sticking on as well. No vacuum on either one will cause the same symptom as vacuum on both.
Old 02-24-2007, 09:14 PM
Sorry. You are correct. Shoulda kept my mouth shut!
Old 02-26-2007, 03:35 PM
cfl4rat's Avatar
well i went to my local junk yard today and pulled of both solenoid's, put them on and BAM i have 4 wheel drive again!!!!!!!!!!!! thanks guys!!
Old 02-26-2007, 05:52 PM
GIJoeCam's Avatar
Glad we could help!
-Joe
Quick Reply: 4x4 solenoid question??// problem?????
