4X4 Question?
Old Dec 27, 2006 | 07:16 PM
Pete W.'s Avatar
Smile 4X4 Question?
Is it possible for the drivers side front wheel to be engaged and the passenger side not? I have a 2001 F-150, 4.6, Manual Trans. and floor shifter for my 4 wheel drive. My drivers side sounds engaged and the passanger side not. Help!! Pete Could the sound be something else?
Old Dec 27, 2006 | 07:38 PM
kingfish51's Avatar
Not possible on your vehicle. The engagement on your vehicle is at the diff, not the wheels. You don't have hubs on your vehicle, just CV joints.
Old Dec 28, 2006 | 10:05 AM
Pete W.'s Avatar
Then what is the problem?
If the four wheel can't be engaged one side at a time then what can the noise be? Hub bearing or cv joint? Thanks
Old Dec 28, 2006 | 12:02 PM
kingfish51's Avatar
That's a possibility. Is the CV boot torn? If so, it almost certainly has dirt in it, and possibly no grease.
Old Dec 28, 2006 | 01:13 PM
Pete W.'s Avatar
CV Boot
CV boot not torn. Just rotated tires to see if was tire noise. Spun both sides when in the air by hand-drivers side spins harder than passenger side. Looks like the bearing.
Old Dec 28, 2006 | 01:43 PM
kingfish51's Avatar
Also check calipers and brakes to make sure they aren't dragging. I believe the bearing hub on those is a one piece sealed unit. Not sure though.
Old Dec 28, 2006 | 01:48 PM
97_4sixer's Avatar
Kingfish you are correct, the bearing hub is a sealed unit. I had to replace the left one on my 97 F150 4x4.
Old Dec 28, 2006 | 04:37 PM
Pete W.'s Avatar
Brakes are fine.
Thanks guys. Could the sound be anything else but a hub bearing?
Old Dec 28, 2006 | 05:19 PM
kingfish51's Avatar
Just because the boot isn't torn, does not mean it isn't a bad CV joint. Probably best bet is to get it diagnosed somewhere that you trust.
