gear ratio setup for lager tires??
I recently posted about my 4x4 drive acting funny. I had a mecanic check it out, for the second time. He noticed I had a 3.21 on the rear, and the front was stock at 3.55. I currently have 35' tires with a 6 inch lift. He reccomended I upgrade the front and the rear too 4.56, due to the fact of the tire size. Or should I just change the rear back to 3.55. I do hate the fact my speedo is off by 20mph, and the lag i get. Please help. I really know nothing about this.
Will this decrease my highend,gasmilage etc
It's about 500.00 to change the rear to stock, our about 1100 to do a 4.56 all around.
your speed would be off by a percentage. i went from 265-70-17's to 34 1/2" tires on my truck and my speedo was off by about 10%. to correct the speedo i changed the plastic gear on the speed sensor which is on the transmission to a gear with 10% fewer teeth. the gear is available at the ford dealer for about $10.
i have 3.55 gears on my truck right now and it is gutless. i am currently in the process of aquiring a set of 4.56 gears for my truck too. it will take alot of pressure off the transmission and engine and use less fuel if there is any difference.
go for the 4.56's with 35" tires. the truck should rev at about 2200 rpm at 70 mph.
