Harley/F-150 differential
I was wondering, how different are 2003 Harley differentials from regular F-150 Screw differentials?
Ever since I slapped on some 22's on my Screw, it has greatly reduced take off power, and also down shifts quite a bit on steep hills.
Are both differentials 8.8? What gears come stock onHarleys? Are Harley posi units as strong as aftermarket units? Do Harley diffs have more splines than F-150's?
I want to upgrade my differential, before I add more performance parts to my Screw, so any help will be greatly appreciated.
4point6
4point6
Since you added bigger wheels and tires, to keep your stock "pick up" off the line you will need to swap gears. I don't know what the harleys come with stock but I'm guessing it can't be over 3.73's. I would go with at least 4.10's maybe lower depending on how much more you want to spend on gas!
Thanks Monte Carlo, and Fordninja for your input. Monte, so you're saying lightnings, harleys, and f-150's come with the 9.75? I though they came with the 8.8......
My local high performance shop quoted me around $750 for an Eaton posi unit and 4.10 gears installed....is that a good price?? I would guess I could get a Harley differential from a junk yard for around that price too; but if I have to also install gears in it, I'm better off rebuilding the one I got on it now.
What do you guys think?
Thanks,
4point6
Thanks,
4point6
I wish I had bought the blower to begin with. The truck is so much more enjoyable to drive, I can't get enough of it.
If that price is for a new Procharger plus install, then it seems like a great deal. I think retail is like $3800, and most shops charge at least $1000 to install it.
If you have the coin you should upgrade your fuel system (injectors, fuel pump, MAF and chip/tune) as well, for the most power. Or you can go the used kit route that I took, the money saved went to the fuel system mods.
Check out the superchager forum. Lots of good info for you in there!
Originally Posted by 4point6
Thanks for the reply Jordan. I see you're packing a Procharger; how do you like it? Is it worth it?
My ultimate goal is to slap one on my Screw. The same shop quoted me $4,200 for an intercooled Procharger, turn key..... is that a good price?
Thanks,
4point6
Thanks,
4point6
