ratio???
Old Nov 23, 2004 | 10:51 PM
racerf150man's Avatar
ratio???
hey does anyone know the code numbers that are on the door...which number is for which ratio???
Old Nov 24, 2004 | 10:28 AM
bigtruck311's Avatar
here you go
18 - 3.08
19 - 3.55
26 - 3.73
27 - 3.31
H9 - 3.55 Limited Slip
B6 - 3.73 Limited Slip
Old Nov 24, 2004 | 03:42 PM
ok thanks i have another ? now. i foudn i the code is h-9 which is 3.55 Limited Slip, my ? is i want more acceleration with out having the truck run too high at highway speed...i live maily in an area where the spped limits are 65-70 on highway... and alot of in town driving. would it be worth it to regear? ... how much does each gear size change the rpm's at 60mph? and how hard of a job is it? driveway work? or shop work?? any help would be great thanks guys!!
Old Nov 24, 2004 | 06:10 PM
if you are a decent mekanic with the right tools(backlash gauge and a micromiter) then the job is not that hard takes me about an hour and a half, just make sure the heel and toe have a good pattern before you slap it together your first time you might half to take it out and chang the pinoin or side shims, ohh you will also need a bearing press to take off and install the new gears, what size tire do you run now?
Old Nov 24, 2004 | 08:24 PM
3.55 Limited Slip
just the stock ones so would it make much differance if i uped it up? what would my rpms at 60 change??
Old Nov 26, 2004 | 01:44 AM
sorry i thought u meant wat gear tire wise i have 285/75r-16 bfgoodrich at kos
Old Nov 27, 2004 | 01:14 PM
way fast witey's Avatar
well,its been my experience that my truck gets better gas mileage if i run about 95 on the interstate(somewhere around 3 grand) so a gear change would put you closer to that at 70,75.
and i purely run 95 for the mileage i would never go faster than the speed limit just for kicks,hehehe.i'm wantin to regear to about 4.10's just for that.maybe it'll help slow me down.a sneaky little motorcycle cop bout got me the other night cause he flew up behind me and didn't have his radar on to let me know he was comin,which would be the least he could do.
Old Nov 28, 2004 | 05:19 PM
noob saibot's Avatar
Wow, I have 3.08 gears that sucks.
I'm going to go to 4.10 around christmas time I think.
